Some keyboard/mouse shortcuts are missing / not working
Dreamer
Post by Dreamer »
Here is the list of some shortcuts - missing form Win version or not working/working incorrectly - I found, please post more if you find some.
in bold - new bugs or still not fixed bugs with changes or new info
:bug: - bug / missing shortcut
:bugconfirmed: - confirmed bug (please quote bugs you can reproduce and post below)
:bugfixed: - fixed bug
:bug: Backspace - doesn't work at all in browser
:bug: :?: Home/End - in browser don't work sometimes (can't reproduce yet)
:bugconfirmed: Numpad Enter works now in view mode and fullscreen, but still doesn't in browser / thumb view
:bugconfirmed: F2 to start batch rename doesn't work at all
:bugconfirmed: F9 to toggle view doesn't work at all (and it's missing also in the shortcuts list!)
:bug: F11 in browser doesn't work (sometimes)
:bug: Alt+left/right to go back/forward in folder history
:bugfixed: :?: I - to toggle (fullscreen) information
:bugconfirmed: Pause - to start/stop quick slideshow - it works in fullscreen, doesn't work in viewer and fullscreen from viewer (are there 2 fullscreen modes also in MP??)
:bugconfirmed: Shift+PageUp/Down - to toggle prev./next page
:bug: Ctrl+R / F5 - one of them should rebuild the thumbnails as in Win version
:bugfixed: Enter doesn't work at all - new info: pressing Enter works, while holding mode is changed to view, after releasing it, it's changed back to browser
:bugfixed: :?: Numpad * in view mode doesn't work good (26 instead of 100% shown)
:bugconfirmed: Ctrl+W to close the current tab
:bug: Numpad / and * don't work in edit mode fullscreen, only when I switch the window (press Alt+Tab twice), then it works only when I click the image once
:bug: Numpad 8, 4, 5, 6, 2 - to move picture (Windows only??)
:bugconfirmed: Numpad 1, 3 - to fit width / height
:bugconfirmed: Numpad 0 - to center
:bugconfirmed: Numpad / - to fit image to window doesn't work in browser/preview, it works only in view mode and it cannot be changed, it's missing in the shortcuts list!
Mouse shortcuts:
:bug: middle click in fullscreen doesn't work, in fullscreen from browser only, when middle click is used to switch between viewer/browser, it should switch to viewer from browser fullscreen
:bugconfirmed: Right click context menu in fullscreen is missing
:bug: middle click unselected thumb - previously selected image is opened instead
:bug: right button + left button - switch between fit to win. / 100%
:bug: right button + middle button - toggle lock zoom
:bugfixed: double click the preview area doesn't work (always)
:bugfixed: double click in fullscreen edit only doesn't work (always)
:bugfixed: middle click in browser doesn't work (sometimes?)
Last update for v 0.26.1*.
* I couldn't update it because of this bug. It's just partly updated for v0.26.1 yet - checked until "***" and mouse shortcuts.
Dreamer
oops66
Re: Some keyboard/mouse shortcuts are missing / not working
Post by oops66 »
Right, for example:
The useful shortcuts "/" works into full screen mode and view mode with the MP Linux version, but not into the browser mode...
About the zoom, it will be also very interesting to have these function too into a future XnView MP version:
sketch a square with the mouse --> to zoom in and fit this area into the window.
zoom steps by a ratio of qrt(2)
http://newsgroup.xnview.com/viewtopic.p ... 024#p77024
Dreamer
Post by Dreamer »
Another update, mouse shortcuts this time.
One very useful mouse shortcut has been added already, thanks, Pierre!!
It's the right button + wheel to zoom in/out and it's even better than in Win version, image is zoomed on cursor position, this is very useful. I think it's because of missing center zoom option, so this behavior should be retained if that option will be added.
The other mouse shortcuts in Win version are a bit limited, so I suggest new functions, of course fully customizable mouse shortcuts would be the best, now it might be a bit easier to implement since keyboard shortcuts are customizable already...
right + left - switch between fit to win. / 100%
right + middle - toggle lock zoom
Left button + wheel (and other combinations) don't work good, since the screen / color is changed when left button is pressed, so I'm not sure if these are needed, but since right/left mouse buttons are customizable, they still make sense.
Dreamer
Dreamer
Post by Dreamer »
Partly updated for v0.21.
Please help to confirm the bugs and missing shortcuts, quote or just copy those you can reproduce and post below. Post also new shortcut-related bugs and missing shortcuts here.
Thanks.
Dreamer
marsh
Post by marsh »
Works v.0.21(L)
:bugfixed: :?: middle click in browser doesn't work (sometimes?)
:bug: middle click in fullscreen doesn't work (sometimes)
*(but there is supposed to be single fullscreen so I would call it "tab fullscreen" indicating starting point rather than function)
Confirmed bugs v.0.21(L):
:bug: Right click context menu in fullscreen is missing
:bug: double click the preview area doesn't work (always)
:bug: double click in fullscreen edit only doesn't work (always)
:bug: F2 to start batch rename doesn't work at all
:bug: Enter doesn't work at all - new info: pressing Enter works, while holding mode is changed to view, after releasing it, it's changed back to browser
:bug: F9 to toggle view doesn't work at all (and it's missing also in the shortcuts list!)
:bug: Numpad Enter doesn't work at all
:bug: Ctrl+W to close the current tab
:bug: Numpad 0 - to center
:bug: Numpad 1, 3 - to fit width / height
:bug: Shift+PageUp/Down - to toggle prev./next page
:bug: :bugfixed: :?: I - to toggle (fullscreen) information
*(not working in tab view here)
:bug: :bug: F11 in browser doesn't work (sometimes)
*(not working in tab view here, sometimes)
:bug: Enter (browser>fullscreen>viewer) works only as "browser>fullscreen"
*(Automatically opens image and closes tab, without chance to look at. )
*(here Alt+left goes to parent folder)
*(here it tries to open both of them!)
Dreamer
Post by Dreamer »
Thank you! Updated in the first post.
Edit: What do you mean by "tab view"? If you mean (menu - view > tab > show), then I can't see any change if tabs are enabled or disabled.
Dreamer
marsh
Post by marsh »
Dreamer wrote:Thank you! Updated in the first post.
I mean an image in viewer, tabs shown. vs. pressing <f11> on image in browser.
Dreamer
Post by Dreamer »
I'm still not sure what do you mean. <I> key for example doesn't work? When you click view tab and you are in viewer? It works good here in browser fullscreen, viewer and viewer fullscreen, if tabs are enabled or disabled.
Anyway, my shortcuts don't work good, some are not default and I can't change them, so I'd wait until that bug will be fixed.
Dreamer
marsh
Post by marsh »
Dreamer wrote:I'm still not sure what do you mean. <I> key for example doesn't work? When you click view tab and you are in viewer? It works good here in browser fullscreen, viewer and viewer fullscreen, if tabs are enabled or disabled.
It wasn't working for me in desktop view. Now it is.
Dreamer wrote: Anyway, my shortcuts don't work good, some are not default and I can't change them, so I'd wait until that bug will be fixed.
I agree.
Dreamer
Post by Dreamer »
Partly updated for v 0.26.1 - more in the first topic. That viewer shortcuts issue is still not fixed. :|
Dreamer
