Problem signature:
Problem Event Name: APPCRASH
Application Name: xnview.exe
Application Version: 0.0.0.0
Application Timestamp: 4abc8e16
Fault Module Name: QtGui4.dll
Fault Module Version: 4.5.2.0
Fault Module Timestamp: 4aaf96fc
Exception Code: c0000005
Exception Offset: 00131c50
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1051
Additional Information 1: 7a6c
Additional Information 2: 41a0337247f1fd67dfad0466efa68645
Additional Information 3: 8d82
Additional Information 4: e023536c8560260a715c1f52013bf292
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
XnViewMP Version 0.20 (Sep 25 2009), Windows Vista 32 bit SP2.
MP 0.20 Win - GPF while dragging the thumbnail slide
Dreamer
JohnFredC
Re: MP 0.20 Win - GPF while dragging the thumbnail slider
Not confirmed here.
Dreamer
It happened only once, I can't reproduce it either, but I remember the same issue from older versions.
Dreamer
Yes in old version, i can't reproduce it...Dreamer wrote:It happened only once, I can't reproduce it either, but I remember the same issue from older versions.
Dreamer
Can't reproduce, considered as fixed.
Dreamer
marsh
Not yet, program sometimes exits with v.0.21(lnx) when I adjust slider. With larger and more numerous png's, the easier it is to recreate). Thumnail cache disabled. Thumbnails view.Dreamer wrote:Can't reproduce, considered as fixed.
Press slider button while on larger end of scale, move left towards small end of scale and release button. The last info from terminal:
LOADED from DB (393)
LOAD BITMAP </home/user/test/Copy (2) of Copy of Copy of pattern.png>
GFF :: LoadThumbnail : 0
LOADED & CREATED
LOADED from DB (391)
LOAD BITMAP </home/user/test/Copy (2) of Copy of pattern.png>
Segmentation fault
Dreamer
