MP 0.20 Win - Minor - Name is not fully visible sometimes
Dreamer
Post by Dreamer »
With default settings, if the name is too long, the first character is not fully visible.
XnViewMP Version 0.20 (Sep 25 2009), Windows Vista 32 bit SP2.
Dreamer
Re: MP 0.20 Win - Minor - Name is not fully visible sometimes
I can't confirm on Xp, which size of thumbnails? Which folder name?
Dreamer
Post by Dreamer »
So it's only on first run when you remove xnview.ini, after one restart it's OK.
To reproduce close xnview, open xnview.ini in notepad, delete all text, save, close, start xnview.
Dreamer
I can't reproduce, perhaps a problem on vista, i'm on Xp
:arrow: Closed (Please post here in case this old problem still occurs with the latest version.)
