0.20: Search issues
Dreamer
0.20: Search issues
Post by Dreamer »
When I type a word and press Enter to search, "Add" button menu is shown instead.
Search button is missing, Apply button doesn't work either.
Search doesn't work at all here, or it's not finished yet. :?
XnViewMP Version 0.20 (Sep 25 2009), Windows Vista 32 bit SP2.
Dreamer
Re: MP 0.20 Win - Search issues
Dreamer wrote: Apply button doesn't work either.
Which test do you have made. For me search works
oops66
Post by oops66 »
xnview wrote:...Which test do you have made. For me search works
FI: Here, with MP Linux v0.20, Search does'nt work if the XnView data base is used, see here:
http://newsgroup.xnview.com/viewtopic.php?f=62&t=18433
...Search button is missing...
If you only use Filename, Right the search button is missing.
Dreamer
Post by Dreamer »
- press ctrl+f
- type a word in the "Filename" field
- press Enter
= "Add" button menu is shown (focus should be on "Apply" button instead of "Add") :bug:
- click the "Apply" * button
= "Searching" dialog is opened, but nothing is found **
= the text of that dialog is still the same - "Searching", it's not clear when (and if) it's done (if nothing is found) :bug: :?:
= "View" button is active even if nothing is found :bug: :?:
= "View" button function is the same as "Browse" in XnView Windows, so it should be the same here - "View" should be changed to "Browse"
* it should be "Search" IMHO
** OK, I got it - wildcards are not supported (yet)
Reason: typo
Dreamer
Dreamer wrote: ** OK, I got it - wildcards are not supported (yet)
Do you use DB? What do you have entered in filename field?
Dreamer
Post by Dreamer »
xnview wrote:Do you use DB? What do you have entered in filename field?
I use DB with ex/in-clude options. As I said, the wildcards option is missing, so "word" is not working, "*word*" works good.
Anyway, the other issues are still actual.
Dreamer
oops66
Post by oops66 »
Resolved with MP linux v0.21-Thank you Pierre.
Dreamer
Post by Dreamer »
Fixed - except:
- press ctrl+f
- press Enter
= "Add" button menu is shown (focus should be on "Apply" button instead of "Add") :bugfixed:
= "Searching" dialog is opened, but nothing is found :bugfixed:
Dreamer
In v0.84 all the above is fixed except:
Dreamer wrote:...
:arrow: Reproduced
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
Dreamer
Post by Dreamer »
Fixed in 0.85b1, thanks, Pierre.
Dreamer
