XnView is a fantastic viewer. Is there any way it can be used to view tiff and pdf images in Internet Explorer. Desparate to get away from Adobe, the only viewer I've found that opens in IE window. Would ideally like to open viewer in IE with toolbars as configured in stand-alone program (to maximize viewing area).
Any help will be great!
XnView as IE plugin
Re: XnView as IE plugin
Thanks, and sorry you can't use XnView in IE.Jyo wrote:XnView is a fantastic viewer. Is there any way it can be used to view tiff and pdf images in Internet Explorer. Desparate to get away from Adobe, the only viewer I've found that opens in IE window. Would ideally like to open viewer in IE with toolbars as configured in stand-alone program (to maximize viewing area).
Christian Ghisler's Total Commander v. M$-IE
Just in case, you might want to know about the Total Commander ("TC") for which XnView works great as a plugin.
Regards.
Regards.
crazytb
