I'm scanning a lot of pictures and find it cumbersome to sort them in the proper order using the automatic sorting criteria provided in XnView.
Sorting manually by visual inspection is needed when I want to sort by picture content.
I would like to have a manual sorting by point-click-and-drag like you can do when sorting slides in PowerPoint.
Then I can subsequently do a batch rename to freeze the sequence.
Sort by click and drag
Dreamer
