I am using XNView 1.96.5.
I got a new wide dispaly and since then all my photos show much too wide.
I'm using 1152x864 resolution and would not like to change it.
I tried all options in Auto Image Size (Fit...), but none seems to solve the peoblem.
Have I missed anything?
XNView compatibility problem with a wide display
MoonStar
Dreamer
Re: XNView compatibility problem with a wide display
This is not an XnView issue, your resolution is not good - 1152x864 has aspect ratio 4:3 and it's not wide, you have to use wide resolution, the best - native resolution with aspect ratio 16:10 or 16:9 (1680x1050 or 1920x1200...). Aspect ratio of your monitor and resolution aspect ratio must be the same!
Dreamer
JohnFredC
Or you could live with dark bars on either side of the 1152 x 864.
But if you have a wide display, why would you choose to remain at 1152 x 864 anyway?
John
