is it possible to automatically rename files with increasing number but with no increasing number if number in previous file name is the same?
I give an example in ordere to explain my question:
Before:
MVI_0771.AVI
MVI_0771.THM
After:
Event_xxxx_002.AVI
Event_xxxx_002.THM
Thanks
Rename files leaving same number
maureol
obelisk
Re: Rename files leaving same number
really a bit over...
you'd never get it sorted like that in the 1st place.
maureol
Sorry, I don't know if I really understood what you wrote (I don't speak English very well): at first ("before") files to be renamed are sorted by capture date.obelisk wrote:really a bit over...
Thanks
