v.21 [linux] Trash folders not used
marsh
Post by marsh »
'use recycle bin' isn't moving anything to standard "Trash" folders (assuming that is where they are wanted).
Re: v.21 [linux] Trash folders not used
Yes, right works only on windows & mac
traskamos
Post by traskamos »
in v.26 [Linux, Ubuntu 10.4] it is still the same. Will it be supported in one of the next versions?
traskamos wrote:in v.26 [Linux, Ubuntu 10.4] it is still the same. Will it be supported in one of the next versions?
On ubuntu, trahs is always here '~/.local/share/Trash/'?
oops66
Post by oops66 »
Yes, for me on Ubuntu 10.04 it's here:
/home/$USER/.local/share/Trash/files/
(~/.local/share/Trash/files/)
                             ... file1.txt
                             ... FOLDER1
                                   ... file4.gz
                              ... FOLDER2
                                    ... filen.deb
traskamos
Post by traskamos »
V.32 Linux / Ubuntu 10.10: Using the Trash for files works fine. For folders it does not work. Was this intended?
By the way, v.32 is great :D It's much faster and more stable than last version.
Thanks
oops66
Post by oops66 »
traskamos wrote:V.32 Linux / Ubuntu 10.10: Using the Trash for files works fine. For folders it does not work...
Right, bug confirmed for folders here too. :bugconfirmed:
oops66
Post by oops66 »
This bug still persist (for folders only) under XnViewMP 0.51 (linux version)
This is dangerous if a lot of pictures were stored into this deleted folder, without a backup (even if "confirm file delete" is checked).
So, into Tool/Settings/General/File Operations/ use "Recycle bin" for folders too.
XnViewMP0.51 linux x64 + Ubuntu 12.04 X64 unity
Edit: same "severe bug" with:
XnViewMP0.56 linux x64 + Ubuntu 12.04 X64
