Metadata icons shown after cleaning
marsh
The extra data icons (thumb,icc, xmp, iptc, exif) are shown after all metadata has been cleaned and program restarted. Thumbnail caching disabled. Optimize thumb db corrects this, but it is unexpected.
Re: Metadata icons shown after cleaning
When you use Clean dialog?
marsh
In thumbnails view with only browser visible. All items checked except optimize.xnview wrote:When you use Clean dialog?
Sorry but i don't understandmarsh wrote:In thumbnails view with only browser visible. All items checked except optimize.xnview wrote:When you use Clean dialog?
marsh
Only some of the overlay icons are updated immediately after using clean metadata. The images have no metadata after cleaning, but the thumbnails still show all the little info icons at bottom after restarting program. All looks normal after erasing db file.xnview wrote:Sorry but i don't understandmarsh wrote:In thumbnails view with only browser visible. All items checked except optimize.xnview wrote:When you use Clean dialog?
Problem still exists in v0.84:
When cleaning a JPG file with EXIF information and embedded thumbnail, the overlay icons "Embedded thumbnail" and "EXIF rotation" are still shown although the image has been cleaned.
1. In browser, navigate to a folder with an image that has EXIF metadata (embedded thumbnail, EXIF rotation, ...)
2. In browser, select "Tools > Meta data > Clean...".
3. In "Clean metadata" dialog check all checkboxes and confirm with "OK".
Actual behaviour (bug): Browser still shows overlay icons for "Embedded thumbnail" and "EXIF rotation".
Expected behaviour: No overlay icons since all metadata has been removed from the image.
A refresh using F5 key doesn't refresh. When browsing a different folder and then returning to the folder, then, the overlay icons are no longer shown.
you can reproduce it each time? the icons are no more here after a cleanhelmut wrote:Problem still exists in v0.84:
Yes, I can reproduce this all the time. Exact steps are written above.xnview wrote:you can reproduce it each time? the icons are no more here after a cleanhelmut wrote:Problem still exists in v0.84:
on Windows 10?helmut wrote:Yes, I can reproduce this all the time. Exact steps are written above.xnview wrote:you can reproduce it each time? the icons are no more here after a cleanhelmut wrote:Problem still exists in v0.84:
Yes, on Windows 10 64 bit.xnview wrote:on Windows 10?
i remember that i had this problem sometimes, but currently i'm not able to reproducehelmut wrote:Yes, on Windows 10 64 bit.xnview wrote:on Windows 10?
i've tried on slow or fast drive...
Perhaps the attached JPEG image (zipped) let's you reproduce the problem. It has an embedded thumbnail, XMP, ITPC, and EXIF data.xnview wrote:i remember that i had this problem sometimes, but currently i'm not able to reproduce
- Forum Librarian
Confirmed for v0.84 32-bit Windows (“Embedded thumbnail” + “EXIF orientation”)
i've re-tried this bug, but can't reproduce it
- Forum Librarian
Did you also do a test with deactivated cache, Pierre?xnview wrote:i've re-tried this bug, but can't reproduce it
