MP 0.21 Win: MP Crashes making thumb of large TIF
JohnFredC
Post by JohnFredC »
I have a very large TIF that consistently crashes MP (GPF) during the create thumbnails activity.
File format: TIFF with LZW compression
File size: 62Mb
Image dimensions: 6637 x 3787
MP 0.21 will not complete thumbnailing the folder because it cannot get past this image.
No problem encountered with XnView 1.9x and this image.
John
JohnFredC
Re: MP 0.21 Win: MP Crashes making thumb of large TIF
Post by JohnFredC »
PS. The large TIF opens directly from the commandline, (though very slowly, with no apparent "low-res" preview).
MP does not crash, however, until I switch to the browser and MP tries to thumbnail the image.
Summarizing this bug: MP crashes trying to thumbnail a large TIFF, but will "view" the file successfully.
John
The crash is only on thumbnail creation? Is it possible to have the file?
JohnFredC
Post by JohnFredC »
Gigantic file, Pierre... 62Mb.
Are you sure you want it?
John
JohnFredC wrote:Gigantic file, Pierre... 62Mb.
Hum, your bug is strange. Do you have other large TIFF file to test?
JohnFredC
Post by JohnFredC »
I have some time today. Will let you know what I discover.
John
JohnFredC
Post by JohnFredC »
OK, I moved that TIFF to a new folder and the original folder finished thumbnailing correctly, even the super-duper large images.
So there is a problem with that specific TIFF file.
The shell menu version of XnView also fails to thumbnail it, but does not crash the way MP does.
Pierre: what else can/should I do? MP displays the file properly, but it just won't thumbnail.
There is no urgency for me, since this appears to be an isolated case.
John
JohnFredC wrote: Pierre: what else can/should I do? MP displays the file properly, but it just won't thumbnail.
It's very strange that XN can load the file and not render the thumbnail. So i need the file :-)
JohnFredC
Post by JohnFredC »
I'll send link to file in PM.
John
JohnFredC wrote:I'll send link to file in PM.
Ok, the problem is with XMP metadata
JohnFredC
Post by JohnFredC »
Is the file bad? I converted it to PNG with no issue.
Just curious.
John
JohnFredC wrote:Is the file bad? I converted it to PNG with no issue.
Just curious.
No a bug in XMP code
