NEF embedded GPS Coordinates Error
PSHRutPark
Post by PSHRutPark »
Hello Pierre,
Whilst testing XnView MP vers0.21 I discovered that the Geo Coordinates for NEF files are listed incorrectly. Upon further checking, I discovered that this error is also exhibited in XnView vers 1.96.5. Versions previous to 1.96.5 had displayed correctly but I don't know when the error first occurred.
The following image illustrates the error with the XnView listing and the correct coordinates as displayed by EXIFTool:
Thanks for the latest releases.
Regards
PETER
Re: NEF embedded GPS Coordinates Error
Could you send me the nef file?
PSHRutPark
xnview wrote:Could you send me the nef file?
Of course. The NEF in the illustration graphic is 16MB. Can I email it to you? Which address?
PETER
you can use yousendit serviec
PSHRutPark
In that case, as an alternative, I have uploaded a NEF to here:
[link now removed]
Thanks
PETER
PSHRutPark
Pierre,
Did you see the GEO Tag display error?
PETER
PSHRutPark wrote: Did you see the GEO Tag display error?
Oui i'll fix it
PSHRutPark
Oui i'll fix it
Thanks
PSHRutPark
Oui i'll fix it
Actually I have noticed that the altitude is also displayed incorrectly. I is correct at 9m in the example of the OP but much higher altitudes (>10m or >100m?) are incorrect. For example an actual altitude of 882m is displayed as 114.01m.
So, only the latitude of NEFs is correct. Incidently, if I save the NEF as a TIFF then XnView list all Geo Tags of the TIFF correctly.
PETER
