Suggestion: Disable fullscreen pop-ups
marsh
Post by marsh »
Hot areas on edge interfere with area selection. Here, I always move mouse from screen corner to screen corner for cropping images. So I think it needs a no-popup option (as default). v.1.96 is a fantastic tool for cropping images because of this feature.
Re: Suggestion: Disable fullscreen pop-ups
Please, could you test XnViewMP 0.25
marsh
Post by marsh »
I'm not sure what has changed. I discovered that it is possible to select the screen though.
Lower left corner isn't "hot". So I can start there and go to upper right corner. Then choose any handle while it is a few pixels from edge.
