Preserving options on U3 device
rodmac51
Post by rodmac51 »
I use XnView on a U3 device but when I make any changes in the 'Tools > options' they are lost when the U3 device is unplugged from the PC. I use the device on various PC's so I need to preserve the options on the actual device, not the PC its plugged in to.
I've tried the 'save to' options' in the Registry and as an 'ini' file in XnView and Windows, but NOT 'User' because I don't what that means? None preserve all the options!
How do I get it to save these options on the U3 device?
Re: Preserving options on U3 device
Do you use the last U3 package?
rodmac51
Post by rodmac51 »
I'm using v1.93.1, which is the latest version on the U3 software site.
rodmac51 wrote:I'm using v1.93.1, which is the latest version on the U3 software site.
Please try the U3 package on my website
rodmac51
Post by rodmac51 »
OK, I've installed v1.96.5 from your website but it still reverts to the default settings when I plug in the U3 device. Which option should I select in Tools>Options>System Integration>Save Options?
rodmac51 wrote:OK, I've installed v1.96.5 from your website but it still reverts to the default settings when I plug in the U3 device. Which option should I select in Tools>Options>System Integration>Save Options?
XnView folder i think
