v.0.21(L) Next button doesn't inherit info from folder tree
marsh
Post by marsh »
In folder tree, switch back and forth between several different folders. You'll see the "Previous" button turn blue.
*The "Next" button remains inactive even while selecting same folders repeatedly in folder tree. It never becomes active unless the "Previous" button is used first.
Re: v.0.21(L) Next button doesn't inherit info from folder tree
Yes it's normal. Next button will be active only if you use Previous. It's the same in folder tree or thumbnail view
