RC3: Minor, easy to "implement" suggestions
Locked
Dreamer
Post by Dreamer »
- change old shortcut for red eyes correction to new in the menu - from Alt+E to Ctrl+E
- add Save As - Ctrl+Shift+S shortcut to the menu
- Info > Thanks > "Thanks to the following Designer:" should be "...Designers:", I think
- rename "Start Slideshow" to "Quick Slide Show" or "Start/Stop Slideshow" or "Start/Stop Quick Slide Show" because Start and also Stop is possible
- High Quality Zoom get lost if I open the Options dialog and click to the OK button
OL
Re: RC1: Minor, easy to "implement" suggestions/bu
Post by OL »
Dreamer wrote:- High Quality Zoom get lost if I open the Options dialog and click to the OK button
It works for me (or I didn't understand)
Dreamer
Post by Dreamer »
It get lost for actual image only, try zoom more, press F12 and Enter, NOT Escape!
It get lost also for High Quality Zoom - Fit to Window/Desktop.
Dreamer wrote:- change old shortcut for red eyes correction to new in the menu - from Alt+E to Ctrl+E
Ok, thanks
Dreamer
Post by Dreamer »
Fixed in RC2, thanks Pierre.
Dreamer
Post by Dreamer »
Dreamer wrote:- rename "Start Slideshow" to "Quick Slide Show" or "Start/Stop Slideshow" or "Start/Stop Quick Slide Show" because Start and also Stop is possible (in viewer and fullscreen standard)
Not fixed in RC3.
Not fixed in RC3.
Ok
Dreamer
Post by Dreamer »
Not fixed in RC3.
Ok
2nd bug fixed in RC4, 1st not, but there is another topic for it, therefore moved to Solved.
Locked
