v.0.21(L) Cache not excluding keywords
marsh
In Cache DB, the option to exclude a folder from use does not stop program from importing keywords and creating categories. The excluded folder should block them to help with downloaded images from sources using another language than your own.
Re: v.0.21(L) Cache not excluding keywords
I've tried, and categories are not created. Could you try with a clean DB file?
marsh
With "[ ]Enable thumbnails caching", categories are automatically created even after old DB is erased. With no folders assigned in 'exclude tab'. Putting folders in 'exclude' does prevent category creation.xnview wrote:I've tried, and categories are not created. Could you try with a clean DB file?
Sorry but i don't understand. If you add folder in 'exclude', categories will not be created for this folder...marsh wrote:With "[ ]Enable thumbnails caching", categories are automatically created even after old DB is erased. With no folders assigned in 'exclude tab'. Putting folders in 'exclude' does prevent category creation.xnview wrote:I've tried, and categories are not created. Could you try with a clean DB file?
'Enable thumbnails caching' is a setting for thumbnail not keywords...
marsh
Thanks for the explanation. No problem then. Indeed, I assumed "[x]import xmp/iptc to db" was thumbnail only.xnview wrote:Sorry but i don't understand. If you add folder in 'exclude', categories will not be created for this folder...marsh wrote:With "[ ]Enable thumbnails caching", categories are automatically created even after old DB is erased. With no folders assigned in 'exclude tab'. Putting folders in 'exclude' does prevent category creation.xnview wrote:I've tried, and categories are not created. Could you try with a clean DB file?
