Xnview seems to pass on bougus timer settings when creating slide.exe files.
Change View>file-list (delay,etc) to 100 which is very fast. Create slide.exe
using <ctrl> + <l>. Now change delay back to 3000ms. Create slide.exe again.
The new slide.exe now runs lightning fast no matter what any new timer settings
are. So changes in timer settings seem to revert to the smallest value ever
placed in timer.
Transition timer also serves as a slide-show timer when enter is pressed.
This is confusing since the delay timer is also used. Does transition
timer only apply to transitions? If so, should it not be measured in
milliseconds?
[OK] RC1: Fast slide.exe bug
See my post
http://newsgroup.xnview.com/viewtopic.php?t=1831
Really? Could you check it out, please (marsh and ckit)?xnview wrote:Fixed.ckit wrote:See my post
