Can't open image with special character in the path
yaurthek
Post by yaurthek »
I have noticed an annoying problem with XnView (I use the last version, 1.96.5 in french) :
When i try to open image (from the windows explorer or from the XnView open menu) with special characters in the path, i get an error and nothing else.
The shell extension menu doesn't work either, the image doesn't appear.
For example : characters like ☺ or  (windows explorer shows a smiley and a dot with these examples)
As you can see, windows is able to show the thumbnail image.
Thanks in advance for taking my post in account.
Re: Can't open image with special character in the path
XnView doesn't support unicode, only XnViewMP support unicode
yaurthek
Post by yaurthek »
So, it's not a bug, it's a feature ? :?
Nothing to hope for next releases ?
Dreamer
Post by Dreamer »
Next release is here already, but it's still beta only...
http://newsgroup.xnview.com/viewforum.php?f=60&start=0
Dreamer
