[OK] RC1: <Page Down> navigation bug with dbl click op
Locked
marsh
Post by marsh »
When Options>Browser>Dbl click or Enter to View in Full Screen is selected,
<Page Down> navigation through browser list is very problematic. It skips
files instead of going to each of them. It works as expected when this
option is unflagged (apart from file order bugs described in another thread).
Re: RC1: <Page Down> navigation bug with dbl click opt
marsh wrote:When Options>Browser>Dbl click or Enter to View in Full Screen is selected,
You have selected this option, and when you use PgDown in browser, you have a strange navigation???? With or without this option, i have the same thing...
marsh
Post by marsh »
Page Down skips files with that option selected. This while viewing them
in full screen. It advances to each files when option is not selected.
Page Down behaves like ms explorer when option is selected.
marsh wrote:Page Down skips files with that option selected. This while viewing them
Ok, when you have the picture in fulscreen mode, PgDown move to the item one page down, and if you load it in view mode, PgDown go to the next item.
So what is the best? Next item?
marsh
Post by marsh »
Going to next item seems best. It should at least act the same way
throughout program.
Locked
