Stripes?
tailormade
Stripes?
Post by tailormade »
I have a 1-bit TIFF file that I need to save as an 8-bit greyscale TIFF. I have tried two ways:
1) Define a second greyscale bitmap and use gflBitblt to copy of one to another. Causes an Unknown format error
2) Define a second greyscale bitmap and go through pixel by pixel and use gflGetColorAt/gflSetColorAt to copy the pixels one by one.
Unfortunately the second one ends up creating a bitmap with 8 vertical strips. Each vertical strip appears to be a squished version of the original page
Here is the code I used:
tBitmap = gflAllockBitmap(GFL_GREY, wid, hgt, 4, NULL);
for (ix = 0; ix < wid; ix++)
	for (iy = 0; iy < hgt; iy++)
		GFL_COLOR color;
		error = gflGetColorAt(bitmap, ix, iy, &color);
		if (error)
			DisplayGflError("", error);
		error = gflSetColorAt(tBitmap, ix, iy, &color);
		if (error)
Re: Stripes?
tailormade wrote: 2) Define a second greyscale bitmap and go through pixel by pixel and use gflGetColorAt/gflSetColorAt to copy the pixels one by one.
Ok, right there is a little bug.
Why you don't use gflChangeColorDepth?
tailormade
Re: Stripes?
Because I need to go from 1-bit to 8-bit grey. At least according to the documentation gflChangeColorDepth only allows you to reduce the number of colors, not increase it.
Re: Stripes?
tailormade wrote:Because I need to go from 1-bit to 8-bit grey. At least according to the documentation gflChangeColorDepth only allows you to reduce the number of colors, not increase it.
No, you can increase too
tailormade
Re: Stripes?
What parameter do you use to go from 1-bit to 8-bit greyscale?
Re: Stripes?
tailormade wrote:What parameter do you use to go from 1-bit to 8-bit greyscale?
GFL_MODE_TO_RGB
