I have second layout:
folder tree at left top
file list at left bottom
preview at right.
Current mode: thumbnails.
After I press Ctrl-End, XnView go to last picture but not highlight last file.
For proving of that selection I press Left key then Right key, selection box draws ok.
Same issue when going to top of list by pressing Ctrl-Home.
WinXP SP3, XnView 1.96.2
No selection box drawing after pressing Ctrl-End / Ctrl-Home
BrokenAutoImageSize
Re: No selection box drawing after pressing Ctrl-End / Ctrl-Home
I've checked, it's the standard behaviour. Only the focus change, not the selection
BrokenAutoImageSize
"loose" focus, so I should press Alt-Tab for return to XnViewxnview wrote:I've checked, it's the standard behaviour. Only the focus change, not the selection
You loose focus after Ctrl+End??BrokenAutoImageSize wrote:"loose" focus, so I should press Alt-Tab for return to XnViewxnview wrote:I've checked, it's the standard behaviour. Only the focus change, not the selection
BrokenAutoImageSize
Sorry, wrong threadxnview wrote:You loose focus after Ctrl+End??BrokenAutoImageSize wrote:"loose" focus, so I should press Alt-Tab for return to XnViewxnview wrote:I've checked, it's the standard behaviour. Only the focus change, not the selection
I mean I post in
http://newsgroup.xnview.com/viewtopic.p ... 65&start=0
Sorry
