Crashing on Snow Leopard
HollieH
Post by HollieH »
Hi:
I just installed and created my categories and started to tag my items but it keeps crashing :(
Is this a Snow Leopard issue?
I was really hoping this was going to replace ACDSee for me.
Thanks!
Re: Crashing on Snow Leopard
HollieH wrote:I just installed and created my categories and started to tag my items but it keeps crashing :(
XnViewMP?
HollieH
Post by HollieH »
Yes, XnViewMP
jofn
Post by jofn »
it happened to me too when I installed snow leopard :(
any fixes?
jofn wrote:it happened to me too when I installed snow leopard :(
any fixes?
Strange, i have no problem on snow. You have the crash when you start it?
jofn
Post by jofn »
^^yes. it opens for 2 sec then it closes on its own and I get the "program closed unexpectedly" or sth sign.
jofn wrote:^^yes. it opens for 2 sec then it closes on its own and I get the "program closed unexpectedly" or sth sign.
Perhaps you have a file in the folder that crash XnView??
jofn
Post by jofn »
do you have any idea what kind of file could cause that?and how come it didn't crash before? the files are the same all .jpg
jofn wrote:do you have any idea what kind of file could cause that?and how come it didn't crash before? the files are the same all .jpg
Could you try to start in a empty folder?
jofn
Post by jofn »
ok I tried it again on an empty folder - no luck. It crashes on the first 2 sec. I don't have any time to click on anything inside the program. This sucks so much I loved xnview on my mac- it's hands down the best image viewing program for me.
HollieH
Post by HollieH »
My problem is similiar. I open a file to tag it, click the catagory tag and then it crashes. I have tried with many different files and its the same. Do you want me to send you a crash report?
Thanks.
jofn wrote:ok I tried it again on an empty folder - no luck. It crashes on the first 2 sec. I don't have any time to click on anything inside the program. This sucks so much I loved xnview on my mac- it's hands down the best image viewing program for me.
Do you have tried to remove the .xnviewmp folder?
HollieH wrote:My problem is similiar. I open a file to tag it, click the catagory tag and then it crashes. I have tried with many different files and its the same. Do you want me to send you a crash report?
If you don't try category tag, do you have problem?
vfxtodd
Post by vfxtodd »
I too have been experiencing XNView crashing on Snow Leopard. Any solutions? New versions?
Thanks in advance.
vfxtodd wrote:I too have been experiencing XNView crashing on Snow Leopard. Any solutions? New versions?
By using which features?
vfxtodd
Post by vfxtodd »
I open XNView. Browse with the side folder view to the DPX I want to view. As soon as I select the DPX file, XNView crashes. If there's another way to view a DPX file or sequence within XNView, please let me know.
