Help file page empty
GeorgD
Post by GeorgD »
Options - interface - interface is empty. I expected information what "Use XP style menu" means as there is also no information available in this forum. => was there an error while compiling help file for 1.96.5?
Here the answer is: Activated, the menus are more narrow, checkmark-area has another background color than the menu item texts, and in view - layout the checkmark appears, elsewise it does not (bug :bug:).
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
Re: Help file page empty
The help file is not finished. Now we use a wiki so you can modify it
GeorgD
Post by GeorgD »
xnview wrote:The help file is not finished. Now we use a wiki so you can modify it
As far as I understood the forum posts, the documentation wiki does not yet contain all content that existed in the current F1-help. Is that true (then I will wait in order to avoid redundant work) or are in the meanwhile all existing documentation texts in the wiki (then I will create the page)? Thanks, Georg
Yes, some page are missing, i'll add them soon
GeorgD
Post by GeorgD »
xnview wrote:Yes, some page are missing, i'll add them soon
OK, please tell me when you've done that, then I'll start adding further content.
GeorgD
Post by GeorgD »
Wiki page created and content added.
