Transparent program window
andrew.hk
Post by andrew.hk »
1.
I really like the XnView, it's one of my favourite every-day tools.
Is it possible to make program window transparent by hotkey or via menu click?
Something like this http://clip2net.com/clip/m8306/12569196 ... -525kb.png
This feature will help to compare two pics overlaying one over another.
For me it would be great tool in my work in web development, it would be easy to check if html page is coded right as it was designed in image file - simply overlay image over browser to see how it fits.
Thank you for your work, I would continue to use the xnview even without this feature :)
2.
Does anybody know tool to make the other program window transparent (for windows xp, vista or 7)?
Re: Transparent program window
andrew.hk wrote:Does anybody know tool to make the other program window transparent (for windows xp, vista or 7)?
:arrow: Window transparency
