To reproduce - go to browser and press F7 > type name > press Enter. I can always reproduce it on Win Vista 32 bit, SP1.
Problem signature:
Problem Event Name: APPCRASH
Application Name: xnview.exe
Application Version: 1.96.0.0
Application Timestamp: 4aeef182
Fault Module Name: ntdll.dll
Fault Module Version: 6.0.6002.18005
Fault Module Timestamp: 49e03821
Exception Code: c0000005
Exception Offset: 00048b02
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1051
Additional Information 1: 53b1
Additional Information 2: 41a40ebc645c403f68c3180db04ff84b
Additional Information 3: 4174
Additional Information 4: b1106ec6bfc74a4563a444f8fc4db031
[FIXED] B1 - GPF on folder creation
Dreamer
Dreamer
JohnFredC
Re: B1 - GPF on folder creation
Confirmed.
Please note that the new folder is actually created and named correctly, however, as inspection after the crash will show.
John
I can't reproduce this bug on Xp or 7
JohnFredC
XP SP3 here.
100% reproducible when creating a folder in the file panel, whether using F7, the context menu, the mini-toolbar, or Edit->New folder.
However: crash does not occur when creating a new folder from the Folder Tree's context menu.
John
ckit
I can confirm this bug under WinXP Pro SP3 x86.
I can't confirm, menu item, F7 or toolbar button create correctly a new folder (XP)JohnFredC wrote:100% reproducible when creating a folder in the file panel, whether using F7, the context menu, the mini-toolbar, or Edit->New folder.
Is it possible to have your .ini?
Dreamer
Important - you have to type the name! F7 > Enter works good, no crash. To reproduce, press F7, type "test", press Enter. I'm using Thumbs & labels view, embedded thumbs and cache disabled.
Dreamer
Ok, i can reproduceDreamer wrote:Important - you have to type the name! F7 > Enter works good, no crash. To reproduce, press F7, type "test", press Enter. I'm using Thumbs & labels view, embedded thumbs and cache disabled.
ckit
Fixed in Beta 2.
Dreamer
