[BUG] wrong thumbnail for .pano files
Jaff
Post by Jaff »
XN will create thumbnail resizing it to max (x,y) XN thumb instead of using ratio resize of image:
^ (ratio 1:1) in XN thumbs for .pano files
Data from .pano file (ratio 1:0.475):
<Thumbnail>
	<Width> 200 </Width>
	<Height> 95 </Height>
	<Depth> 32 </Depth>
	<Data>.....
Sugestion: Thumb is stored in hex 32 bit Alpha+R+B+G interleaved (Alpha value can be used to generate a thumb with any desired background in XN [ex: background of browser])
AutoPano Giga screenshot:
Windows Explorer screenshot (thumbs via AutopanoShell_win32.dll):
Imi este indiferent ce cred ceilalti despre mine, caci oricum fiecare crede ce-i convine lui si nu ceea ce e real, doar ca mi-ar fi placut sa ma vada asa cum sint de fapt, nu asa cum poate le-ar placea lor sa creada. Ei au ales deja...
Re: [BUG] wrong thumbnail for .pano files
Is it possible to send me a .pano?
Jaff
Post by Jaff »
download link in PM for images used & pano's and for those who are passioned by pano's: AutoPano Giga 2 32 bit / 64 bit
Jaff wrote:download link in PM for images used & pano's and for those who are passioned by pano's: AutoPano Giga 2 32 bit / 64 bit
Ok, it's not XnView that create thumbnails for .pano :-) but AutoPano, so you can ask Alexandre about this problem...
Jaff
Post by Jaff »
I will. In Total Commader/Windows Explorer look ok so in XN it should be just like in others applications. Anyway, maybe sometime you can add minimum .pano support to generate thumbs, but that's another story. Thanks.
Jaff wrote:I will. In Total Commader/Windows Explorer look ok so in XN it should be just like in others applications. Anyway, maybe sometime you can add minimum .pano support to generate thumbs, but that's another story. Thanks.
Sorry, i've checked again and yes all is ok in explorer, and not in xnView!
