XMP wordwarp
Jaff
XMP wordwarp
Post by Jaff »
Please add wordwarp for XMP window in browser mode view and even better, display warped lines at ">" char (end of elements in XMP)
Thanks!
Imi este indiferent ce cred ceilalti despre mine, caci oricum fiecare crede ce-i convine lui si nu ceea ce e real, doar ca mi-ar fi placut sa ma vada asa cum sint de fapt, nu asa cum poate le-ar placea lor sa creada. Ei au ales deja...
Re: XMP wordwarp
XMP pane must be changed, XnViewMP use a better view of XMP data
Jaff
Re: XMP wordwarp
Post by Jaff »
Displaying with CR/LF instead of LF only should solve this problem.
Sugestion:
Checkbox in Edit IPTC data window for:
* "Use LF instead of CR/LF" (Photoshop compatibility)
* write IPTC in UNICODE"
* cleanup XMP padding (spaces betwen </x:xmpmeta> and <?xpacket end="w"?>) for smaller file instead of fast update of XMP in file (need checking if new XMP fits into old XMP space). EXIF tool writes spaces and a LF every 100 spaces
EDIT: Editing IPCT + Writing with no changes (but with update XMP option) will write XMP differently than Rebuild XMP
