RC1: Capture does not work using F12 key?
marsh
Post by marsh »
I cannot get capture to work using F12 key. Anyone else seeing this?
Same with v.1.74 as mentioned in old thread:
http://newsgroup.xnview.com/viewtopic.php?t=1788
Re: RC1: Capture does not work using F12 key?
marsh wrote:I cannot get capture to work using F12 key. Anyone else seeing this?
Yes, i don't know why. I don't receive any event from F12 key...
I've just tried using F12 key. Does not work for me either. So I suggest to simply remove the appropriate entries in the list of trigger keys.
Ok, i remove it
Fixed in RC5 (F12 key has been removed from list.) Postponed - perhaps this can be really fixed later.
