Removing exif increases the file size
lesnaja
Post by lesnaja »
File size increases after removing exif of file in jpg - it is not very correct. It would be better if the file size decreases.
Re: Removing exif increases the file size
could you send me a jpeg sample?
:arrow: lesnaja
:) Hello ! Welcome aboard !
• This could happen when the JPEG quality in the Options is higher than the original one.
- Despite the subtraction of the Exif data, the image ones themselves are getting bigger when saved…
- Just a thought …
:mrgreen: Kind regards,
