Is there any way to move the category settings to an other computer? I already installed xnview and moved the pictures but the category setting got lost.
Felix12
Transfer category
Felix12
Re: Transfer category
but I can not find the file
Felix12
Thank you for the quick response. Please can you tell me, where exactly I can find it.
- Forum Librarian
Felix12 wrote:Please can you tell me, where exactly I can find it.
- Hit WinKey+R to open the Run... dialog box.
- Type explorer.exe /select,"%APPDATA%\XnView\category.db" and click OK.
Felix12
Guys you are great, works perfect. Is there any way to change the path of category.db? e.g. to "My Documents"
category.db & xnview .db are saved in same folder (opion/Thumbnail>Cache - Folder)Felix12 wrote:Guys you are great, works perfect. Is there any way to change the path of category.db? e.g. to "My Documents"
jotess
I would like to transfer the settings (categories etc.) from a machine with WinXP to one with Win7. So the structure of the path to the images has changed and just copying the file is no use. Is there another way to manage this transfer? Is there a way to edit the db file?
Joachim
Joachim
yes, do you know sql language?jotess wrote:I would like to transfer the settings (categories etc.) from a machine with WinXP to one with Win7. So the structure of the path to the images has changed and just copying the file is no use. Is there another way to manage this transfer? Is there a way to edit the db file?
Joachim
jotess
Unfortunately not. But as I know now that it is an sql database I know at least what I would have to investigate.
Joachim
Joachim
if you send it to me, i can make the change...jotess wrote:Unfortunately not. But as I know now that it is an sql database I know at least what I would have to investigate.
Joachim
