"Select all" - menu item is incorrect
Dreamer
Post by Dreamer »
Since "select all" option (menu item, shortcut) has been changed, the name should be changed too. Perhaps to "Toggle select all", or "Select all - toggle".
Dreamer
JohnFredC
Re: "Select all" - menu item is incorrect
Post by JohnFredC »
If "Select All" in the menu is now a toggle, perhaps it should have a check mark?
John
Dreamer
Post by Dreamer »
Good suggestion, in that case renaming is not needed...
Dreamer
Dreamer
Post by Dreamer »
Still the same in beta 3, any chance to change it, or postpone?
Dreamer
Dreamer wrote:Still the same in beta 3, any chance to change it, or postpone?
Yes postpone
