1.96b2 "Rating & colour label lost after renamed" not fixed?
GeorgD
Post by GeorgD »
According to the changelog, "Rating & colour label lost after renaming" - http://newsgroup.xnview.com/viewtopic.php?f=36&t=17377 is fixed in 1.96b2. On my Win XP, when I rename a file in Windows Explorer, the rating is still lost. Or was it only fixed for renaming within XnView which works fine? /Georg
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
Re: 1.96b2 "Rating & colour label lost after renamed" not fixed?
GeorgD wrote:According to the changelog, "Rating & colour label lost after renaming" - http://newsgroup.xnview.com/viewtopic.php?f=36&t=17377 is fixed in 1.96b2. On my Win XP, when I rename a file in Windows Explorer, the rating is still lost. Or was it only fixed for renaming within XnView which works fine? /Georg
I've changed when you rename in XnView browser, in windows explorer, i can't!
GeorgD
Post by GeorgD »
xnview wrote:I've changed when you rename in XnView browser, in windows explorer, i can't!
OK, renaming within XnView is working fine so far :)
As mentioned in several forum threads, it would be great to have the ratings also stored within image metadata so ratings etc work on other computers and after move/rename/changed drive letters (just a reminder ;-) )
GeorgD wrote:As mentioned in several forum threads, it would be great to have the ratings also stored within image metadata so ratings etc work on other computers and after move/rename/changed drive letters (just a reminder ;-) )
XnViewMP has this feature...
GeorgD
Post by GeorgD »
xnview wrote:XnViewMP has this feature...
Yes and it works fine. A pitty that XnView MP does not yet have many other functions I often use...but MP is still young ;)
