Hello, When I open my .c4 drawings, they appear scrambled, like blocks of a jig saw puzzle.
The file does open, and I have set file associations to add .c4/edmics.
Any suggestions? I have a file I can send of needed.
Properties show compression @ "CCITT Group 4", and format @ Edmics Group 4.
Scrambled .c4 edmics drawing upon opening to read
DrDaveVa
Re: Scrambled .c4 edmics drawing upon opening to read
• In theory, *.c4 (Edmics) is supported at reading only. Please, let's know which XnView version and OS you are using.
- I didn't find out any *.c4 here à home, so please give us a valid URL to download a sample
(just add some "_" whether the forum stuff refuses your link).
DrDaveVa
Hi Claude,
We are using version 1.96.5 (Sept 16, 2009)
OS is Windows XP, Service Pack 3.
Can you provide an email address, and I can send a file for your review.
I don't know how to give you a URL.
Thank you for your help.
• I said an URL (some image host or remote directory on your site, supposing you have one), not an e-mail address !
- Please, remove your e-mail address ("Edit") to avoid spams !
- Try from Filter Menu >> ImageShack to place your sample on such an host.
- Note : You can send the sample to the Author (only…) to
webmasterATxnviewDOTcom
