Crash
Crash
On http://fileforum.betanews.com/detail/Xn ... 89386705/1, some users seems to have problem with beta, crash when you try to open some files.
Do you have same crash?
Re: Crash
:arrow: Pierre
:) Hello !
• No problem with ß-3 here till now opening usual image formats under XP-Pro SP2…
:mrgreen: KR
RazR83
Re: Crash
Post by RazR83 »
Another crash on 1.97:
  1. Tools - Options - Interface - "Add 'Exit' to context menus" must be checked
  2. Open an image (view mode) and Zoom+
  3. Right click and then left click on "Exit"...
If "Ctrl+Q" - no bug! :shock:
Error log:
xnview.exe
   1.97.0.0
   4b0f9896
   xnview.exe
   1.97.0.0
   4b0f9896
   c0000005
   000d71c4
   be8
   01ca6f8624a7a0f9
   C:\Program Files\XnView\xnview.exe
   6c1cd03f-db79-11de-8816-aa7d6014c1ac
ckit
Re: Crash
Post by ckit »
RazR83 wrote:Another crash on 1.97:
Error log:
xnview.exe
   1.97.0.0
   4b0f9896
   xnview.exe
   1.97.0.0
   4b0f9896
   c0000005
   000d71c4
   be8
   01ca6f8624a7a0f9
I can't reproduce this bug on my rig (check sig)
RazR83
Re: Crash
Post by RazR83 »
ckit, try on high resolution pictures (like 2736x3648)...
ckit
Re: Crash
Post by ckit »
Tried using 3648x2048 (aspect ratio 1.78) wallpaper from dA and still no crash, what zoom stepping are you using?
I'm using the default.
RazR83
Re: Crash
Post by RazR83 »
Hm-m-m-m, very strange :|
Dreamer
Re: Crash
Post by Dreamer »
Confirmed! But I can't always reproduce it, only 2 of 6 crashes - now 3 of 9...
Edit: now still only 3 of 20, strange.
Screen res. 1680x1050, picture res. 9MPX.
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	xnview.exe
  Application Version:	1.97.0.0
  Application Timestamp:	4b0f9896
  Fault Module Name:	xnview.exe
  Fault Module Version:	1.97.0.0
  Fault Module Timestamp:	4b0f9896
  Exception Code:	c0000005
  Exception Offset:	000d71c4
  OS Version:	6.0.6002.2.2.0.768.3
  Locale ID:	1051
  Additional Information 1:	53b1
  Additional Information 2:	41a40ebc645c403f68c3180db04ff84b
  Additional Information 3:	9e4b
  Additional Information 4:	f1787b086c09c6a94d238b0c36944e20
Hardware: CPU Intel Core 2 Duo E8400 3GHz, RAM 4GB, GPU GeForce 8800GT 512MB, Audio X-Fi XtremeGamer, HDD1 WD 640GB, HDD2 WD 640GB, DVB-S card SkyStar 2 r2.3, Monitor Samsung 215TW 21"...
Software: OS Windows Vista Home Premium 32bit SP2, DirectX 10, ForceWare 185.85, TechniSat DVB 4.4.1, IE8, AIMP, Ashampoo Burning Studio, avast! Antivirus, AviDemux, Comodo Firewall, CyberLink PowerDirector, DVB Dream, FFDShow, Foxit Reader, FreeCommander, HotkeyP, IZArc, Media Player Classic, OpenOffice.org, Orca Browser, Photofiltre, PSPad Editor, PTBSync, Skype, Spybot, TeamViewer, Trillian, TrueCrypt, VirtualDub, VLC, Xnview, ZipGenius...
Dreamer
RazR83
Re: Crash
Post by RazR83 »
Dreamer wrote:But I can't always reproduce it, only 2 of 6 crashes - now 3 of 9...
Also! And can't catch regularity... :shock:
ckv
Re: Crash
Post by ckv »
I also could reproduce this few times. I didn't even need to zoom the image to get the crash.
Second chance exception 0xC0000005 (Access Violation) occurred in "XNVIEW.EXE" at address 0x004D71C4.
Re: Crash
Please postponed...
Dreamer
Re: Crash
Post by Dreamer »
Beta testing is over, moved to Bug reports.
Dreamer
