Webshots - Changed format
Mikepics
Post by Mikepics »
Hi
The New Webshots uses a different format - wb1 I believe.
Will XnView be updated to support the new format??
Re: Webshots - Changed format
Mikepics wrote:The New Webshots uses a different format - wb1 I believe.
Could you send me some examples, please?
Regards. Pierre.
IceMan
I want to know also if you are going to support this.
Post by IceMan »
Thanks!
Re: I want to know also if you are going to support this.
IceMan wrote:I want to know also if you are going to support this.
Not yet.
bergerado
webshots new .wb1 format
Post by bergerado »
In order to continue this old thread in Pierre's monosyllabic fashion:
When?
My assumption is that Webshots (i.e. the C-Net company) does not like to give away the new .wb1 image code for proprietary reasons, am I not right?
Otherwise you would surely have implemented it with one of your latest XnView 1.8 versions, be it only to maintain its reputation of being 'the most versatile image file viewer that money doesn't have to buy' ;-) !
Kind regards,
Andreas
Drahken
Post by Drahken »
Where do you get wb1 files anyway? All I get from webshots is wbz files (which work just fine in xnview).
In the meantime, there are at least 2 progs which claim to be able to convert wb1 files to JPGs or other formats:
http://uwc.apinc.org/index.php?lang=en
and
http://k-lug.org/~griswold/Progs/webshots.html
Assuming they work (since I have no wb1 files to test them with), they should fill the gap until xnview supports wb1 files.
mII
wb1
Post by mII »
a third one: Konvertor :)
Re: webshots new .wb1 format
bergerado wrote:In order to continue this old thread in Pierre's monosyllabic fashion:
When?
If you have wb1 could you send me it?
cdm
Webshots files
Post by cdm »
Since I've updated to the latest version of XnView I've lost the ability to view and convert webshot files (wbz).
I've used XnView for a long time and am disappointed that it no longer read or converts webshots pictures (wbz).
I look forward to a new version which regains this ability.
Re: Webshots files
cdm wrote:Since I've updated to the latest version of XnView I've lost the ability to view and convert webshot files (wbz).
Do you have enabled option/General/Startup/Use all formats?
