Dragging tagged files outside XnView is impossible
Dreamer
When dragging the tagged files outside XnView, no dialog (use tagged/selected files) is displayed (instead the selected file(s) is/are used), so it's not possible to drag the tagged files from XnView to explorer, or file manager. The only way is to show all tagged files option and then go back. I'm not sure if it's a bug, but I don't see any reason why that dialog shouldn't be displayed in this case too.
Dreamer
Re: B3 - Dragging tagged files outside XnView is impossible
Same in 1.96? Drag&drop is always with selected files
Dreamer
I think so, but I'd like to drag the tagged files. Now I have to:
- click "Tag"
- select all tagged files
- drag the files
- press Back button
- and find last selected image
Too many unnecessary steps.
- click "Tag"
- drag the files
- press Back button
Dreamer
Need a topic for that, it's a change of current behavior
Dreamer
