YUV resolution
amia
YUV resolution
Post by amia »
I am trying to use YUV files with no headers.
How can I present them well on XnView? (The defualt presentation is as 256x256 24bpp and I cannot find a way to modify it)
Thanks
Re: YUV resolution
you can change option/read-write/read/yuv
amia
Re: YUV resolution
Post by amia »
I tryed changing it and it changes resolution but the colors are wrong. Probably the YUV have different types of organizations. In raw format theer are several types but are RGB based. Can you assit?
Re: YUV resolution
In File/Open, you can choose the YUV format (yuv16, yuv422, ...)
amia
Re: YUV resolution
Post by amia »
Thanks! I'm almost there. Selecting Y411 displayed correctly but as a single frame not as video. What do I need to do there?
Re: YUV resolution
XnView support only 1 frame loading
