v.0.21(L) Other files not placed in program folder
marsh
Post by marsh »
Options... Integration>Folder used for other files [XnView]
When using the above option, files other than ini are placed in "~/.xnviewmp" folder instead.
This doesn't occur in windows version.
[Start]
otherFlag=1
otherFolder=
Choosing program folder through custom works.
otherFlag=2
otherFolder=/home/user/programs/xnviewlx/
Re: v.0.21(L) Other files not placed in program folder
Please, could you test XnViewMP 0.25
marsh
Post by marsh »
Fixed v.25(L). Other items were transferred alright from .xnviewmp to custom folder.
marsh
Post by marsh »
A problem remains when choosing program folder for 'other' files:
1. Choose a custom folder to place other files.
2. Try program. Restart.
3. Change setting for 'other' files to 'xnview'.
4. *The db file is becomes misnamed and placed in program's parent folder.
/home/user/prog/xnviewlxXnView.db
Settings:
[Start]
otherFlag=1
otherFolder=/home/user/mnt/q/wip_q/xnviewlx/
Program directory I'm using: /home/user/prog/xnviewlx
Could you try XnViewMP 0.26
marsh
Post by marsh »
Switching from "user" to "XnView" creates a new "xnviewlxXnView.db" above the program folder in v.0.26 (and this db is used).
If program folder is renamed "mp", then the db created is called "mpXnView.db"
Settings:
before:
otherFlag=0
otherFolder=
after
otherFlag=1
otherFolder=
