Wrong range of values
Danny
Post by Danny »
Some of the filters that have the black, white and expansion limit seem to have the wrong range of values. Take the map -> normalize setting for example.
They 3 settings all don't seem to change anything in the image above a value of 99, but you can set it as high as 255. It says "%" after the fields, so that may explain why.
They're generally kinda weird, but since i have no clue what algorithm is happening in the back, i can't know how it's supposed to work. So it may actually be correct that way... Like the white limit in the map->align setting doesn't seem to take more than 49%.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
