Can you support the free RAW Container-Format DNG from Adobe?
Info: www.adobe.com/dng
Thanks!
[OK] RC1: DNG-Support?
Re: DNG-Support?
Yes DNG is supportedMisterXP wrote:Can you support the free RAW Container-Format DNG from Adobe?
PECourtejoie
Dreamer
I agree.PECourtejoie wrote:Then it might be wise to list it on the supported formats page... Barry Pearson reported that DNG does not seem to be supported because he did not find it in that list.
Therefore moved backt to General Support group.
BTW - Next time please start new topic in main group, don't reply to closed topics.
