RAW (Pentax) preview slow
DrSlony
Post by DrSlony »
Hi
XnView-1.96.5 full
WinXP SP3
1.6GHz 1 core
768MB RAM
1- When opening my Pentax k10d RAW files (extension: pef) either fullscreen or in the viewer, the file opens very slowly, about 2-4 seconds. I set everything related to RAW files I could find to use the embedded JPG thumbnail, so showing it should be 'instant'. No need for demosaicing.
2- What's more, I enabled caching the next/previous image. Lets call the current image A and the next image B. If I switch to B right after opening A, I have to wait those 2-4 seconds. If I wait those 2-4 seconds after opening A before opening B, and only then open B, then B loads instantly.
3- Now regardless of 2, going from B to A should be instant. It isn't. 2-4 seconds, always, regardless how long I wait.
Any ideas or advice? Is opening RAW (PEF) files using the embedded JPG 'instantly' possible?
[Load]
CRAWAutoBalance=0
CRAWBlueScaling=1.00
CRAWBrightness=0.80
CRAWCameraAutoBright=1
CRAWCameraBalance=1
CRAWGamma=0.60
CRAWHighResolution=1
CRAWRedScaling=1.00
ChannelOrder=0
ChannelType=1
DjVuMaxDpi=0
Dpx32Pack=0
EXIFDpi=0
EXIFRotate=1
ExrGamma=1.00
GrobBpp=0
HdrGamma=1.00
Height=256
ICCDef=0
ICCDefProfileName=
ICCFlags=0
ICCProfile=0
ICCProfileName=
IcoIn32bits=1
IgnoreError=0
Lut10to8Name=
Offset=0
PcdBase=2
PddPage=0
PngComposeWithAlpha=0
PngComposeWithTransparency=0
PostscriptDpi=72
PostscriptPageSize=0
Preview=1
UseEmbeddedThumbnail=1
UseLut=0
UseOrgIfSmall=0
WMFHighResolution=0
Width=256
YuvHeight=576
YuvOffset=0
YuvWidth=720
[Process]
AutoView=0
Deinterlace=0
FilterAutoView=0
ShowPreview=1
[View]
AppFitToImage=0
BackColor=0
BackgroundColor=8421504
CRAW=2
CacheBehind=0
ColorInfo=0
CopyClipboard=0
DeleteGoNext=1
DirKeyFlag=0
DirKeyVFlag=0
DisableGifAnimation=0
EnableBmpAnimation=0
Fit=3
Gamma=1.00
GridColor=255
GridSize=2
GridSpacingX=80
GridSpacingY=80
GridType=1
HideScrollBar=0
HighZoomQuality=1
IgnoreAlpha=0
ImageLoop=0
KeepGridForNextPrevious=0
LeftButtonFlag=1
LockZoom=0
MouseNavigation=0
NoMultipleView=0
OneViewMultiple=0
OnlyOneView=0
OpenHexaViewIfNotPicture=0
PlayMovie=1
PlaySound=1
ReadAhead=1
ResetXY=0
RightButtonFlag=1
ScrollVal=10
ShowColorInfo=0
ShowText=1
SlideDelay=1000
SlideDirection=0
SlideLoop=1
SpaceKeyFlag=0
StatusInfo=0
Text=<Directory><Filename>||Tag: <Tag status>
UnitsSize=0
UseAlpha=1
UseBgImg=0
UseDPIRatio=1
UseGamma=0
UseTranspIndex=1
UseUndo=1
UseZoomStep=0
UserSelHeight=0
UserSelRatioX=0
UserSelRatioY=0
UserSelWidth=0
UserSelXdpi=0
UserSelYdpi=0
VideoFitAll=0
VideoLoop=0
VideoPlayBar=1
WheelMouseFlag=2
ZoomStep=10
marsh
Re: RAW (Pentax) preview slow
Post by marsh »
With Options... View>Misc>Camera Raw> [Embedded thumbnail], the item in ini file should read:
[View]
CRAW=0
