So. How to convert a jpg or a gif to pbm?
cos if use the command: nconvert -out pbm house1.jpg
will get: This picture cannot be written using this format
thanks
convert jpg to pbm
Re: convert jpg to pbm
add: -binary dither
Thanu
I've have tried the commands 'nconvert -i me.gif -o pbm' and 'nconvert -out pbm me.gif' but both commands are giving a message saying 'Cant create file ,mz.gif'. Please help me with this.
add '-binary floyd'
Thanu
Thanks for your reply, but still have not luck with it. I used the command 'nconvert -out pbm mz.gif -binary floyd'. I got the following error messages:
Can't create file <mz.gif>
Cant create file <-binary>
Cant create file <floyd>
Please help me with this asps. I am running the command in XnView folder, mz.gif file is located in there too.
Thanks
Thanks
No try
nconvert -out pbm -binary floyd mz.gif-
Thanu
well, the program is crashing each time i try to run that command.
Unhandled exception at 0x00528939 in nconvert.exe: 0xC0000005: Access violation reading location 0x0000000c.
is there any file format I should be trying from?
Really??
Could you send me your jpg?
