ICA Files
shane24
ICA Files
Post by shane24 »
I'm looking to open an ICA (IOCA) image file. The website says the file type is supported in XNview, but I am unable to open it. Is there a certain plugin I need for this? I am able to open the file in a program called Hijaak.
I've read this post but still can't open them. http://newsgroup.xnview.com/viewtopic.p ... oca#p72198
Re: ICA Files
'Display all file formats' is checked?
shane24
Re: ICA Files
Post by shane24 »
I have "Display all image file types" checked. I do not see "Display all file formats".
The error I receive says "Format of the file <E1111.ICA> could not be determined".
Re: ICA Files
XnView doesn't support all IOCA format
