Show image size in browser mode?
barnyjoe
Post by barnyjoe »
hi ... first I will thank you for this great program ... :) but I have some customizing problems.
1) how can I display only the image size in browser mode ... normal there is shown the file name
2) how can I make the left column bigger? If i select the bar with the left mouse button clicked there is nothing happend ...
Is is generally possible to show a different color in browser-mode for images with a size <= 200px width for example ... ?
Info: latest xnview version 1.97 on win xp 32-bit ...
barnyjoe
Re: Show image size in browser mode?
Post by barnyjoe »
O.K ... the first question is now right for me ... "View - View as - Thumbnails & Labels" ... with the special Labels defined. But why can I make the left column bigger? This action works in the most other windows apps.
Thank you for support ... barny
ckv
Post by ckv »
barnyjoe wrote:O.K ... the first question is now right for me ... "View - View as - Thumbnails & Labels" ... with the special Labels defined. But why can I make the left column bigger? This action works in the most other windows apps.
Make sure you don't have LockLayout = 1 set in your xnview.ini or in your registry.
barnyjoe
Post by barnyjoe »
O.K ... thank you - "LockLayout = 1 set in your xnview.ini" was exactly what I'm searching for. barny
