Any chance to add reading/displaying (in browser) exif tags from Sigma X3F raw files ?
Thx !
any chance to add reading exif tags from Sigma X3F raw files
deejjjaaaa
Re: any chance to add reading exif tags from Sigma X3F raw files
Could you send me a sample?
deejjjaaaa
several Sigma DP2 raw files are publicly available here - http://www.rytterfalk.com/2009/05/13/dp2-raw-pack-iixnview wrote:Could you send me a sample?
and there is also a mixed set of DP1, DP2 and SD14 raw files (Sigma's X3F format) - http://www.rytterfalk.com/raw/mixed_raw_pack.zip
that should be good enough for a start ?
thank you in advance !
deejjjaaaa
you probably have seen that, but just in case :
http://www.photofo.com/x3f-raw-format/
http://www.photofo.com/downloads/x3f-raw-format.pdf
http://www.stv.ee/~donq/sigma/s/x3f-016.tgz
Ok, thanks. I'll take a lookdeejjjaaaa wrote: that should be good enough for a start ?
deejjjaaaa
embedded JPG is displayed in browser even now - but if you can also display as many (at least basic) exif tags (ISO, f-stop, etc) - that will be very good, even if you will not be able display the raw data itself !xnview wrote:Ok, thanks. I'll take a lookdeejjjaaaa wrote: that should be good enough for a start ?
deejjjaaaa
any chance to get that done at all ?
Roland Karlsson updated his source code ("c/c++") to read the updated .X3F format = http://proxel.se/x3f.html = http://github.com/rolkar/x3f
that might be helpful to add the functionality to read exif tags...
It seems that this tools doesn't support EXIF tags from X3Fdeejjjaaaa wrote: Roland Karlsson updated his source code ("c/c++") to read the updated .X3F format = http://proxel.se/x3f.html = http://github.com/rolkar/x3f
deejjjaaaa
Look what I can see (I am not a software developer though) :xnview wrote:It seems that this tools doesn't support EXIF tags from X3Fdeejjjaaaa wrote: Roland Karlsson updated his source code ("c/c++") to read the updated .X3F format = http://proxel.se/x3f.html = http://github.com/rolkar/x3f
if I will take his utility "x3f_extract" and run it like:
x3f_extract -jpg [.X3F raw file]
then I will get an embedded .JPG thumbnail extracted from .X3F and that .JPG ___has correct EXIF tags___ that we are looking for... I am right now looking at both files in XnView and see that myself.
so either
1) his code (where the source is available) can in fact read EXIF tags from .X3F
__OR__
2) the embedded JPG thumbnail itself is in fact .JPG file __with necessary EXIF data included__ ...
in this last case XnView already has access to embedded JPG thumbnail and you can just get the EXIF tags from there instead of .X3F - even easier for you to implement...
Am I right ? that will be awesome ! please.
