in WinXP all my favorites with names that contains swedish letters malfunction. What happens:
The letters change to Ã¥, ä and ö (å, ä and ö), the folder icon disappears and the favorite does not work.
Bug: Favorites with swedish letters malfunction
Troken
Re: Bug: Favorites with swedish letters malfunction
The descript.ion file is ok? the problem is with favorite name or folder name?
Troken
I can not find any descript.ion. Do you mean "bookmark.ini"? It seems to be alright. The swedish letters are there correctly.
Here is a print screen of the error...
I am using XP at the moment, but I can check other systems as well if you'd like.
Houps sorry, yes bookmark.ini. So bookmark.ini is correct. And in the bookmark menu?Troken wrote:I can not find any descript.ion. Do you mean "bookmark.ini"? It seems to be alright. The swedish letters are there correctly.
Troken
You mean this? It is wrong also:
Troken
Hey, I started to add new folders... its just getting more weird. And now there are strange symbols in the 'bookmark.ini' too, so it also becomes faulty.
If you remove your bookmar.ini, and you add folders, do you have the problem again?Troken wrote:Hey, I started to add new folders... its just getting more weird. And now there are strange symbols in the 'bookmark.ini' too, so it also becomes faulty.
Troken
Yes, its still there.xnview wrote:If you remove your bookmar.ini, and you add folders, do you have the problem again?
bookmark.ini is in UTF8?Troken wrote:Yes, its still there.xnview wrote:If you remove your bookmar.ini, and you add folders, do you have the problem again?
Troken
I have no idea. In Notepad++ it says: ANSI as UTF-8
and
* Encode in ANSI
Encode in UTF-8
Encode in UCS-2 Big Endian
Encode in UCS-2 Little Endian
and
* UTF-8 without BOM
Can that help you? I will mail you the file.
and
* Encode in ANSI
Encode in UTF-8
and
* UTF-8 without BOM
Yes please send me itTroken wrote: Can that help you? I will mail you the file.
Troken
The bug is no more with 0.25, thank you, works fine now! Good job!
