beginner Q: easiest way to print a 3:4 format jpg on 3:2 pap
Mattgerman
Post by Mattgerman »
Hi all,
quite happy using xnview. But having troubles with printing?
All my images are in the 4:3 format but I would like to print out borderless on 3:2 format (such as 10x15). So, what is the easiest process? Should I use the image and crop the 3:2 portion and modify the image?
thanks for your help,
Matt
