Hi!
I set up "Auto image size" to "No fit". When I press "/" CURRENT image is fit to window. That's all ok.
But how to make XnView TO STORE LAST image status: 'no fit' (like it was set up in Options) OR 'fit' (if hot key "/" is pressed).
For example - browsing 5 images with "No fit" option:
image1 - no fit,
image2 - no fit,
-- now we pressing "/" --
image3 - fit to window
image4 - no fit again!
image5 - no fit.
How to lock fit after "image3"?
P.S. Sorry fo my English.
Fit on not to fit
oops66
Re: Fit on not to fit
Maybe in Options\View\Auto Image size = Fit image to window all (instead Fit image to window, large only or else)
Or in Options\View\FullScreen\Auto Image size = Fit image to window all (instead Fit image to window, large only - by default) ?
piko
Hello!oops66 wrote:Hello,
These options are works as they must to work, but I need something else.
I want to know how to lock fit mode of the CURRENT image if hot keys "/" or "*" was pressed, and apply this mode to ALL following images (not only this one).
...That's works fine in ACDSee, but I don't understand how to make it with XnView. Maybe XnView doesn't have such feature...
Hmm, perhaps "Look zoom" (View > Lock Zoom)?piko wrote:... I want to know how to lock fit mode of the CURRENT image if hot keys "/" or "*" was pressed, and apply this mode to ALL following images (not only this one).
piko
Unfortunately, it's locks percent of zoom of current image. It's only suitable if all images in folder have the same size (width and height).helmut wrote:Hmm, perhaps "Look zoom" (View > Lock Zoom)?
