XnView v1.97 (LIBFORMAT v5.54) 27/11/2009:
Fixed:
* Export dialog, 100% used by default - viewtopic.php?f=34&t=18044
Several times I use a big zoom (i.e. bigger than 100%) in the export dialog in order to optimize jpeg settings while controlling the visual artifacts on-line.
XnView 1.97 resets the zoom to 100% at every setting change making impossible to perceive small changes at pixel level.
While the default 100% zoom is welcome, the continuous reset certainly isn´t.
This is really annoying and I hope it can be fixed in the next maintenance release.
O.S.: XP sp3
Regards.
Also posted at: http://newsgroup.xnview.com/viewtopic.p ... 044#p80413
